光学传感器#
介绍#
EXP 光学传感器 结合了 RGB 颜色传感器和接近传感器,可检测附近物体的颜色、亮度和是否存在。它还可以利用内置 LED 灯照亮物体,以实现更精确的检测。
VEX EXP 光学传感器。
This page uses optical_sensor as the example Optical Sensor name. Replace it with your own configured name as needed.
以下是可用方法列表:
  • set_light – Turns the Optical Sensor’s LED on or off.
  • set_light_power – Sets the Optical Sensor’s light power level.
  • is_near_object – Returns whether the Optical Sensor detects an object within range.
  • color – Returns the color detected by the Optical Sensor.
  • brightness – Returns the amount of light reflected from the object.
  • hue – Returns the hue detected by the Optical Sensor.
  • object_detected – Registers a function to be called when the Optical Sensor detects an object.
  • object_lost – Registers a function to be called when the Optical Sensor loses an object.
构造函数 - 手动初始化光学传感器。
  • Optical – Creates an Optical Sensor.
设置灯光#
set_light turns the Optical Sensor’s LED on or off. This can help increase the sensor’s accuracy when detecting colors.
Usage:
optical_sensor.set_light(state)
参数
描述
状态
Sets the LED on or off. LEDStateType.ON turns the light on at 100% brightness. LEDStateType.OFF turns it off.
# Turn on the sensor's LED
optical_sensor.set_light(LEDStateType.ON)
设置灯光功率#
set_light_power sets the brightness of the Optical Sensor’s LED. The light can help the Optical Sensor detect objects and colors more clearly.
如果光传感器的灯熄灭,将灯光功率设置为 0% 以上即可打开灯。
如果光传感器的指示灯亮着,将光功率设置为 0% 将关闭指示灯。
百分比越高,灯光越亮;百分比越低,灯光越暗。
Usage:
optical_sensor.set_light_power(percent, units)
参数
描述
百分比
将 LED 亮度设置为整数。
单位
Optional. The unit to represent the brightness: PERCENT
# Turn on the sensor's light at half brightness
optical_sensor.set_light_power(50, PERCENT)
靠近对象#
is_near_object returns a Boolean indicating whether or not the Optical Sensor detects an object within range.
  • True – The Optical Sensor detects an object.
  • False – The Optical Sensor does not detect an object.
Usage:
optical_sensor.is_near_object()
参数
描述
此方法没有参数。
# Drive forward until an object is found
drivetrain.drive(FORWARD)
while not optical_sensor.is_near_object():
  pass
drivetrain.stop()
颜色#
color returns an instance of a Color class, based on the detected hue value. These can be compared to predefined Color objects to create conditional statements.
可选颜色有:
  • Color.BLACK
  • Color.WHITE
  • Color.RED - A hue value between 340° - 20°
  • Color.GREEN - A hue value between 80° - 140°
  • Color.BLUE - A hue value between 200° - 240°
  • Color.YELLOW - A hue value between 40° - 60°
  • Color.ORANGE - A hue value between 20° - 40°
  • Color.PURPLE - A hue value between 240° - 280°
  • Color.CYAN - A hue value between 140° - 200°
Note: The Optical Sensor is looking for hue ranges that match the specified color. For detecting specific hue ranges, see hue.
Usage:
optical_sensor.color()
参数
描述
此方法没有参数。
# Drive forward until red is found
while not optical_sensor.color() == Color.RED:
  pass
drivetrain.stop()
亮度#
brightness returns the amount of light reflected from the object as a decimal (float) representing a percent.
百分比越高,意味着反射回光学传感器的光线越多;百分比越低,意味着反射回的光线越少。
Usage:
optical_sensor.brightness()
参数
描述
此方法没有参数。
色调#
hue returns the hue value of the detected color as a decimal (float) from 0 to 359.
色相是用色轮上的数字来描述颜色的一种方法。
VEX 色轮,显示围绕圆周的颜色度数,红色为 0 度,随着数值增加,颜色依次过渡到彩虹的颜色。
Usage: optical_sensor.hue()
参数
描述
此方法没有参数。
# Look for the color pink using hue
while True:
  brain.screen.clear_screen()
  brain.screen.set_cursor(1, 1)
  if 300 < optical_sensor.hue() < 359:
    brain.screen.print("This is pink!")
  else:
    brain.screen.print("No pink detected!")
检测到目标#
object_detected registers a function to be called whenever the Optical Sensor detects a new object.
Usage:
optical_sensor.object_detected(callback, arg)
参数
描述
callback
先前定义的 函数,当光学传感器检测到新物体时执行。
arg
可选。包含要传递给回调函数的参数的元组。有关更多信息,请参阅使用带参数的函数。
def my_function():
  brain.screen.print("Optical Sensor detected an object")
# Call my_function whenever optical_sensor detects an object
optical_sensor.object_detected(my_function)
丢失对象#
object_lost registers a function to be called whenever the Optical Sensor loses a detected object.
Usage:
optical_sensor.object_lost(callback, arg)
参数
描述
callback
先前定义的 函数,当光学传感器丢失检测到的对象时执行。
arg
def my_function():
  brain.screen.print("Optical Sensor lost an object")
# Call my_function whenever optical_sensor loses an object
optical_sensor.object_lost(my_function)
构造器#
Constructors are used to manually create Optical objects, which are necessary for configuring an Optical Sensor outside of VEXcode.
Optical#
Optical creates an Optical Sensor.
Usage:
Optical(smartport)
范围
描述
smartport
The Smart Port that the Optical Sensor is connected to, written as Ports.PORTx where x is the number of the port.
# Create an Optical Sensor in Port 10
optical_sensor = Optical(Ports.PORT10)
