Motor 393 (Controlador de motor 29)#
Introducción#
The motor29 class is used to control a Motor Controller 29 connected to a 3-Wire Port. The Motor Controller 29 sends a PWM signal from the V5 Brain to operate a VEX Motor 393.
El controlador de motor VEX 29.
Constructores de clases#
1 — Creates a motor29 object on the specified 3-Wire Port.
motor29(
    triport::port &port );
2 — Creates a motor29 object on the specified 3-Wire Port and changes the positive turning direction.
motor29(
    triport::port &port,
    bool           reverse );
Instructor de clase#
Destroys the motor29 object and releases associated resources.
~motor29();
Parámetros#
Parámetro
Tipo
Descripción
port
triport::port&
The 3-Wire Port that the Motor Controller 29 is connected to, written as Brain.ThreeWirePort.X or ExpanderName.X, where X is the port letter (for example, Brain.ThreeWirePort.A or Expander1.A).
reverse
bool
Sets whether the motor’s spin direction is reversed:
  • false (default) — Does not reverse the motor’s direction.
  • true — Reverses the motor’s direction.
Ejemplo#
// Create a Motor Controller 29 instance in 3-Wire Port A
motor29 Motor393_A = motor29(
    Brain.ThreeWirePort.A );
Funciones de los miembros#
The motor29 class includes the following member functions:
  • giro — Hace girar el motor en una dirección específica.
  • parada — Detiene el motor.
  • setVelocity — Indica al Motor 393 a qué velocidad debe girar.
  • setReversed — Establece si se invierte el sentido de giro del motor.
Before calling any motor29 member functions, an instance must be created, as shown below:
Motor 393 configuration is generated automatically
as needed. */
spin#
Hace girar el motor 393 en la dirección especificada indefinidamente.
Funciones disponibles
1 — Gira usando la velocidad configurada actualmente.
void spin(
 directionType dir );
2 — Gira a la velocidad especificada.
void spin(
 directionType dir,
 double        velocity,
 velocityUnits units );
Parámetros
Parámetro
Tipo
Descripción
dir
directionType
The direction in which the motor spins: forward or reverse.
velocity
double
The velocity to spin with from 0% to 100% when using percent.
units
velocityUnits
The velocity unit:
  • percent / pct — percent
  • rpm — rotations per minute
  • dps — degrees per second
Valores de retorno
Esta función no devuelve ningún valor.
Notas
  • Esta función no requiere espera y el proyecto continuará ejecutándose inmediatamente después de la llamada.
  • The Motor 393 will continue spinning until stop is called or another spin is used.
stop#
Detiene el motor.
void stop();
Parámetros
Esta función no requiere ningún parámetro.
Valores de retorno
setVelocity#
Indica al motor 393 a qué velocidad debe girar. Un porcentaje mayor hace que el motor 393 gire más rápido y un porcentaje menor hace que gire más lento.
Cada proyecto comienza con cada motor 393 girando al 50% de su velocidad por defecto.
void setVelocity(
    double velocity,
    percentUnits units );
Parámetros
Parámetro
Tipo
Descripción
velocity
double
units
percentUnits
The velocity unit:percent / pct — percent
Valores de retorno
setReversed#
void setReversed(
    bool value );
Parámetros
Parámetro
Tipo
Descripción
value
bool
Whether the Motor 393’s direction is reversed:
  • true — Reverses the Motor 393’s direction.
  • false — Returns the Motor 393’s direction to its default.
Valores de retorno
Notas
  • Calling setReversed is the same as changing the reverse parameter in the constructor.
