Motor Victor 883#
Introducción#
The motor_victor class is used to control a Victor 883 Motor Controller connected to a 3-Wire Port. The Victor 883 Motor Controller sends a PWM signal from the V5 Brain to control compatible VEXpro or VEX EDR DC motors that cannot be connected directly to Smart Ports.
El controlador de motor Victor 883 no se puede configurar en VEXcode y debe construirse manualmente mediante código para poder utilizarse.
Constructores de clases#
1 — Creates a motor_victor object for the Victor 883 Motor Controller connected to the specified 3-Wire Port.
motor_victor( triport::port& port );
2 — Creates a motor_victor object on the specified 3-Wire Port and optionally reverses its direction.
motor_victor(
 triport::port& port,
 bool           reverse );
Instructor de clase#
Destroys the motor_victor object and releases associated resources.
~motor_victor();
Parámetros#
Parámetro
Tipo
Descripción
port
triport::port&
The 3-Wire Port that the Victor 883 Motor is connected to, written as Brain.ThreeWirePort.X or ExpanderName.X, where X is the port letter (for example, Brain.ThreeWirePort.A or Expander1.A).
reverse
bool
Sets whether the motor’s spin direction is reversed:
  • false (default) — Does not reverse the motor’s direction.
  • true — Reverses the motor’s direction.
Ejemplo#
// Create the motor_victor instance on 3-Wire Port A
motor_victor victor = motor_victor(Brain.ThreeWirePort.A);
// Create the motor_victor instance with reversed direction
motor_victor victor2 = motor_victor(Brain.ThreeWirePort.B, true);
Funciones de los miembros#
The motor_victor class includes the following member functions:
  • spin — Spins the motor in a specified direction.
  • stop — Stops the motor.
  • setVelocity — Tells the motor how fast to spin.
  • setReversed — Sets the motor direction to be reversed or not.
Before calling any motor_victor member functions, a motor_victor instance must be created, as shown below:
/* This constructor is required to use a
Victor 883 Motor. Replace the values
as needed. */
spin#
Hace girar el motor en la dirección especificada indefinidamente.
Available Functions
1 — Hace girar el motor utilizando la velocidad del motor configurada actualmente.
void spin(
 directionType dir );
2 — Hace girar el motor a la velocidad especificada.
void spin(
 directionType dir,
 double        velocity,
 velocityUnits units );
Parameters
Parámetro
Tipo
Descripción
dir
directionType
The direction in which the motor spins: forward or reverse.
velocity
double
The velocity to spin with from 0% to 100% when using percent.
units
velocityUnits
The velocity unit:
  • percent / pct — percent
  • rpm — rotations per minute
  • dps — degrees per second
Return Values
Esta función no devuelve ningún valor.
Notes
  • The motor will continue spinning until stop is called or another movement function is executed.
Examples
// Spin forward, then stop
victor.spin(forward);
wait(1, seconds);
victor.stop();
// Spin forward at 100 rpm
victor.spin(forward, 100, rpm);
wait(1, seconds);
victor.stop();
stop#
Impide que el motor gire.
Available Functions
void stop();
Parameters
Esta función no acepta ningún parámetro.
Return Values
Notes
  • Calling stop immediately stops any current motor movement.
Examples
// Spin and then stop
wait(1, seconds);
victor.stop();
setVelocity#
Indica al motor a qué velocidad debe girar. Un porcentaje mayor hace que el motor gire más rápido y un porcentaje menor hace que gire más lento.
Cada proyecto comienza con cada motor conectado girando al 50% de su velocidad máxima por defecto.
Available Functions
void setVelocity(
    double       velocity,
    percentUnits units );
Parameters
Parámetro
Tipo
Descripción
velocity
double
units
percentUnits
The velocity unit:percent / pct — percent
Return Values
Notes
  • Any subsequent Victor 883 Motor movement function (such as spin) that does not explicitly specify a velocity will use this value.
Examples
// Set velocity to 50%, then spin
victor.setVelocity(50, percent);
setReversed#
Permite configurar si el sentido de giro del motor debe invertirse o no.
Available Functions
void setReversed( bool value );
Parameters
Parámetro
Tipo
Descripción
value
bool
Whether the motor’s direction is reversed:
  • false — Returns the motor’s direction to its default.
Return Values
Notes
  • This is the same as changing the reverse parameter in the constructor.
Examples
// Reverse the motor direction
victor.setReversed(true);
victor.spin(forward); // Will actually spin in reverse
