使用事件#
Using Events
This tutorial covers how to use events in VEXcode IQ (1st gen). By the end, you’ll know how to broadcast an event and have another stack of blocks respond to it.
Events let separate stacks of blocks in a project communicate with each other, using blocks from the Logic - Events category. Blocks whose names begin with broadcast signal that an event has happened, and blocks whose names begin with when run their attached stack of blocks in response.
Add a broadcast block or a broadcast and wait block to your project.
Screenshot of the Logic - Events toolbox category, with the broadcast and broadcast and wait blocks highlighted.
Select the dropdown on the broadcast block to choose an existing event, or to create, rename, or delete an event.
Screenshot of the broadcast block's dropdown open, showing the my_event option along with New event, Rename event, and Delete the "my_event" event options.
Add a when I receive block to the workspace, and set its dropdown to match the event name used in your broadcast block. Then, attach blocks below it as those blocks will run whenever that event is broadcast.
Screenshot of the Logic - Events toolbox category, with the when started and when I receive blocks highlighted.
Once a when I receive block matches the event name used by a broadcast block, running the project lets both stacks run at the same time. For example, the robot will turn until the Brain’s Check button is pressed, then broadcasts an event that stops the robot from driving.
When started, turns until the Check button is pressed, then broadcasts an event that stops the robot when it’s received.#
当开始
[右 v] 转
等到 <Brain [确认 v] 键按下了?>
广播 [my_event v]
当我收到 [my_event v]
驱动停止
Blocks starting with when can also be found with other device categories, running their attached blocks whenever that device’s condition is met. For example, the when Brain button and when Bumper blocks.
The when Brain button hat block.#
当Brain [▲ v] 按键 [按下 v]
The when Bumper hat block.#
当 [Bumper1 v] [按下 v]
