移动爪子#
Moving the Claw
This tutorial covers how to move the claw on your Clawbot IQ in VEXcode IQ (1st gen). By the end, you’ll have a project that closes the claw, waits, then opens it again.
Make sure your robot is configured with the Drivetrain, Gyro version of the Clawbot IQ build, so you see the ClawMotor blocks in the toolbox.
  1. Attach the spin motor for block to the when started block. This closes the claw.
The spin motor for block, closing the ClawMotor.#
当开始
[ClawMotor v] [关闭 v] 转 (90) [度 v] ▶
  1. Attach a wait block below it, to pause before opening the claw again.
A wait block, below the spin motor for block.#
当开始
等待 (1) 秒
  1. Attach another spin motor for block below the wait block.
A second spin motor for block, below wait.#
当开始
等待 (1) 秒
  1. Change its direction parameter to open, to open the claw back up.
Screenshot of the finished project, with the second spin motor for block's direction dropdown open, showing close and open options, and open selected.
  1. Make sure your robot is connected to VEXcode, then select Download to download the project to the Brain.
Screenshot of the VEXcode IQ (1st gen) toolbar with the Download button highlighted.
  1. Select Run to run the project. This project will now close the claw, wait, then open it again.
Screenshot of the VEXcode IQ (1st gen) toolbar with the Run button highlighted.
