Σύνδεση δύο ρομπότ#
Link both robots#
The linking animation will play while the robots are linking. Make sure both robots are within Bluetooth range of one another.
Note: When linking, a robot will try to connect with the closest robot to it. Be mindful of this if you are linking more than one pair of robots at the same time.
Indicator status will change#
The robots will show green once the linking is finished and the indicator icon in the top-left corner of the screen will show that the robots are now linked.
View the linked robot’s name#
Select the i on the bottom of the home menu to access the Info screen.
Check the Info screen details#
The linked robot’s name will appear at the bottom of the info screen.
