If Then Blocks#
If Then Blocks
This tutorial covers how to use if/else blocks to make your robot check a condition and decide which blocks to run. By the end, you’ll know how to set up a condition and control what happens when it’s true or false.
Drag a Boolean block into the empty condition slot in the if then branch.
A controller pressed Boolean block being dragged into the empty condition slot of an if/else block.
All Boolean blocks are hexagon-shaped and have a question mark in their name, such as the controller pressed? block.
An if/else block with a controller R up pressed Boolean block, with the Boolean block highlighted.
If the condition is true, the blocks inside the if then branch will run.
An if/else block with a controller R up pressed Boolean block and a drive forward block, with the drive forward block highlighted.
If the condition is false, the blocks inside the else branch will run.
An if/else block with a controller R up pressed Boolean block, a drive forward block, and a stop driving block, with the stop driving block highlighted.
An if/else block only checks its condition once. If you want the condition to be checked repeatedly, put the if/else block inside a looping block, like forever.
An if/else block nested inside a forever block.#
por siempre
si <¿botón [R ▲ v] del Control presionado?> entonces
conducir [adelante v]
si no
detener conducción
fin
fin
The if block is only the if then branch. If the condition isn’t true, nothing will happen.
The if block.#
fin
The if / else if / else block can be used to test multiple conditions one after another. It can be expanded to test as many conditions as needed.
An if/else if/else block, testing all three Brain buttons.#
si <¿botón [▲ v] del Brain presionado?> entonces
girar [izquierda v] por (90) grados ▶
si no, si <¿botón [▼ v] del Brain presionado?> entonces
girar [derecha v] por (90) grados ▶
si no, si <¿botón [Verificar v] del Brain presionado?> entonces
detener conducción
si no
fin
