Mover el brazo#
Moving the Arm
This tutorial covers how to move the arm on your Clawbot IQ in VEXcode IQ (1st gen). By the end, you’ll have a project that raises the arm.
Make sure your robot is configured with the Drivetrain, Gyro version of the Clawbot IQ build, so you see the ClawMotor and ArmMotor blocks in the toolbox.
  1. Attach the spin motor for block to the when started block.
The spin motor for block, spinning the ClawMotor by default.#
cuando inicie
girar [ClawMotor v] [cerca v] por (90) [grados v] ▶
  1. Change its motor parameter to ArmMotor, to control the arm.
Screenshot of the spin motor for block's motor dropdown open, showing ClawMotor and ArmMotor options, and ArmMotor selected.
  1. Change its distance parameter to 180, to move the arm 180 degrees from its current position.
Screenshot of the spin motor for block, with the distance field highlighted, set to 180.
  1. Make sure your robot is connected to VEXcode, then select Download to download the project to the Brain.
Screenshot of the VEXcode IQ (1st gen) toolbar with the Download button highlighted.
  1. Select Run to run the project. This project will now raise the arm up.
Screenshot of the VEXcode IQ (1st gen) toolbar with the Run button highlighted.
