Utilizar la ayuda#
Using Help
This tutorial walks you through using the Help tab in VEXcode IQ (1st gen). By the end, you’ll have looked up what a block does using the Help tab.
  1. Select the Help tab in the top-right of VEXcode.
Screenshot of VEXcode with the Help tab highlighted, showing the default Blocks Help message.
  1. Select a block from the toolbox or in your workspace to open the Help information for that block. Each Help entry includes information about the block’s parameters, an example demonstrating its behavior, and any additional graphics to help you understand the block.
Screenshot of the Help tab showing the print on screen block's Help entry, including its description, parameters, and an example.
  1. To start re-creating the example shown, select the lock icon. This makes sure VEXcode won’t open a new Help page if you select a different block.
Screenshot of the Help tab with the lock icon highlighted, above the print on screen block's Help entry.
