Naming and Saving Your Project#
Select the Project Name#
Select the name of your project at the top of VEXcode.
Screenshot of the VEXcode toolbar, with the project name VEXcode Project highlighted.
Type a New Name#
A dialog box will open. Type in a new name for your project.
Screenshot of the Save Project As dialog, with the project name field highlighted.
Save Your New Name#
Once you’ve entered a new name, select Save to open the saving dialog for your device.
Screenshot of the Save Project As dialog, named Competition Test 1, with the Save button highlighted.
View the Saved Project#
Once the project is saved, its name will appear at the top of VEXcode. VEXcode will also start auto-saving your project as you work.
Screenshot of the VEXcode toolbar, showing the saved project name Competition Test 1 with a checkmark icon.
Save Your Project Manually#
Open the File Menu#
Select File in the top-left of VEXcode to open the File menu. Then, select Save to save the project, or Save As to save it with a new name.
Screenshot of the File menu open, with the Save and Save As options highlighted.
