Device Setup: Controller#
Add a Controller#
Open the Devices Tab#
Select the Devices tab.
Screenshot of VEXcode's tab bar, with the Devices tab highlighted.
If the Devices tab is not visible, see Add a Tab in the Navigating VEXcode tutorial.
Select Add a Device#
Select Add a Device in the Devices tab.
Screenshot of the Devices tab, with the Add a Device button highlighted.
Select Controller#
Select Controller from the devices menu.
Screenshot of the Select a device screen, with Controller highlighted.
Set Controller Actions#
The Controller’s buttons and joysticks are shown, labeled by name. If you have a Drivetrain and/or Motor configured, you can assign controls for them here. These configured actions only run during a project while the Controller enable/disable block has them enabled.
Set a Button to Control a Motor#
Selecting a button lets you choose which pair of buttons will control that device — one button for the forward direction, and the other for reverse.
Screenshot of the Select buttons to set actions screen, showing the up and down D-pad buttons set to control Motor4's forward and reverse directions.
If you have a Drivetrain configured, selecting a joystick toggles through the following control schemes:
Left Arcade#
The left joystick controls both the Drivetrain’s forward and reverse movement and its turning.
Screenshot of the Select buttons to set actions screen, showing the left joystick set to control the Drivetrain's movement and turning together.
Right Arcade#
The right joystick controls both the Drivetrain’s forward and reverse movement and its turning.
Screenshot of the Select buttons to set actions screen, showing the right joystick set to control the Drivetrain's movement and turning together.
Split Arcade#
The left joystick’s up and down controls the Drivetrain’s forward and reverse movement, while the right joystick’s left and right controls turning.
Screenshot of the Select buttons to set actions screen, showing the left joystick's up and down set to control forward and reverse movement, and the right joystick's left and right set to control turning.
Tank Drive#
The left joystick’s up and down controls the left side of the Drivetrain, and the right joystick’s up and down controls the right side, independently.
Screenshot of the Select buttons to set actions screen, showing the left and right joysticks' up and down each set to control their own side of the Drivetrain.
Finish Adding the Controller#
Select Done to add the controller to your robot.
Screenshot of the Select buttons to set actions screen, with the Done button highlighted.
View the Controller in Your Devices List#
The controller will now appear in your list of devices, and the Controller category and blocks will be added to your toolbox.
Screenshot of the Devices tab, showing Controller1 in the list of devices.
