Moving and Removing Blocks#
Blocks can be moved, rearranged, and deleted in a project.
Add and Move Blocks#
Add a Block to Your Project#
To add a block to your project, click and drag the block from the toolbox, and release to drop it into the workspace.
Screenshot of a drive forward for 200 mm block being dragged from the toolbox into the workspace.
Attach Blocks Together#
Drag a block to other blocks in order to attach them together.
Screenshot of a wait 1 seconds block being dragged to attach below a drive forward for 200 mm block.
Move a Group of Blocks#
By clicking a block that’s above others, you can move entire groups of blocks together.
Screenshot of a set drive velocity to 25% block and its attached print block being dragged together as a group.
Insert Blocks into a Stack#
Dragging a stack of blocks above others allows you to insert them into the stack of blocks.
Screenshot of a group of blocks being dragged and inserted between a when started block and the rest of a stack of blocks.
Remove Blocks#
Delete a Block#
To delete a block, right-click the block and select Delete Block from the context menu. You can also select the block and press the delete key on your keyboard.
Screenshot of the right-click context menu on a print block, with Delete Block highlighted.
