Connecting to Your Robot#
This tutorial walks you through connecting your robot to VEXcode GO. By the end, you’ll have your robot connected wirelessly over Bluetooth.
Press the power button on the Brain to turn it on.
Select the Connect button at the top-right of VEXcode.
Select Connect next to Bluetooth, under the Wireless Connection section.
Select your robot from the list.
Select Pair.
Once connected, the Wireless Connection section will show Bluetooth as Connected, and the Brain section will show its Device Name, Battery, and Firmware.
To disconnect, select Disconnect.
