Naming and Saving Your Project#
This tutorial walks you through naming and saving a project in VEXcode GO. By the end, you’ll have saved your project under a new name.
  1. Select the name of your project at the top of VEXcode.
Screenshot of the VEXcode toolbar, with the default project name highlighted, showing a warning icon since it hasn't been saved yet.
  1. A dialog box will open. Type in a new name for your project.
Screenshot of the Save Project As dialog, with the project name field highlighted.
  1. Select Save to open the saving dialog for your device.
Screenshot of the Save Project As dialog, with the Save button highlighted.
  1. Once the project is saved, its name will appear at the top of VEXcode. VEXcode will also start auto-saving your project as you work.
Screenshot of the VEXcode toolbar, showing the saved project name with a checkmark icon.
  1. You can also save manually at any time. Select File in the top-left of VEXcode, then select Save to save the project, or Save As to save it with a new name.
Screenshot of the File menu open, with the Save and Save As options highlighted.
