Detecting Colors#
This tutorial walks you through using the Eye Sensor to detect a color, using a Green Disk as an example. By the end, you’ll have a project that prints a message once green is detected.
Make sure your robot has an Eye Sensor connected. See Configuring Devices if you haven’t added one yet.
Attach a set eye light block below the when started block. This helps the Eye Sensor detect colors more clearly.
when started :: hat events
set eye light [on v]
Attach a wait until block below it.
wait until <>
Drag the Eye Sensor’s eye detects color Boolean block into the wait until block’s condition slot.
wait until <eye detects [red v]?>
Change the color parameter to green.
Attach a print block below the wait until block.
wait until <eye detects [green v]?>
print [VEXcode] ▶
Change its text to Green detected!.
Make sure your robot is connected to VEXcode. See Connecting to Your Robot if it isn’t connected yet.
Select Start to run the project.
Hold a Green Disk in front of the Eye Sensor. Once it’s detected, Green detected! will print to the Console.
