Starting a Project#
Starting a Project
By the end of this tutorial, you’ll know how to start and stop your projects.
  1. Make sure your robot is connected to VEXcode. See Connecting to Your Robot for more information.
Screenshot of the VEXcode GO toolbar, with the Connect button highlighted showing a Connected state.
  1. Select Start to run your project on the robot.
Screenshot of the VEXcode GO toolbar, with the Start button highlighted.
  1. A dialog shows your project’s progress as it loads, then starts automatically once it finishes.
Screenshot of the Starting Project dialog, showing a progress bar as the project initializes on the robot.
  1. Select Stop to stop the project.
Screenshot of the VEXcode GO toolbar, with the Stop button highlighted.
