Apertura de un proyecto#
Opening a Project
This tutorial walks you through opening a saved project in VEXcode IQ (2nd gen). By the end, you’ll have your project loaded and ready to work on.
Select File in the top-left of VEXcode, then select Open.
Navigate to and select the project file that you want to open.
The project name at the top of VEXcode will change to show the name of the file you just opened, and VEXcode will start auto-saving your project.
