Moving Your Robot#
Moving Your Robot
This tutorial walks you through using the drive for block to move your robot forward and backward in VEXcode IQ (2nd gen). By the end, you’ll have a project that drives your robot forward, then in reverse.
  1. Make sure your robot is configured with a Drivetrain, so you see the Drivetrain blocks in the toolbox. See Configuring a Drivetrain if you haven’t added one yet.
Screenshot of the toolbox with the Drivetrain category open, showing its drive blocks.
  1. Attach two drive for blocks below the when started block.
Two drive for blocks connected below when started.#
cuando empezó
unidad [adelante v] para (200) [mm v] ▶
  1. On the second block, change the direction parameter to reverse.
The second block’s direction changed to reverse.#
cuando empezó
unidad [atrás v] para (200) [mm v] ▶
  1. Make sure your robot is connected to VEXcode, then select Run to run the project. The robot will drive forward, then drive the same distance in reverse.
Screenshot of the VEXcode IQ (2nd gen) toolbar with the Run button highlighted.
