Naming and Saving Your Project#
This tutorial walks you through naming and saving a project in VEXcode IQ (2nd gen). By the end, you’ll have saved your project under a new name.
  1. Select the name of your project at the top of VEXcode.
Screenshot of the VEXcode IQ (2nd gen) toolbar, with the project name VEXcode Project highlighted.
  1. A dialog box will open. Type in a new name for your project.
Screenshot of the Save Project As dialog, with the project name field highlighted.
  1. Select Save to open the saving dialog for your device.
Screenshot of the Save Project As dialog, named Competition Test 1, with the Save button highlighted.
  1. Once the project is saved, its name will appear at the top of VEXcode. VEXcode will also start auto-saving your project as you work.
Screenshot of the VEXcode IQ (2nd gen) toolbar, showing the saved project name Competition Test 1 with a checkmark icon.
  1. You can also save manually at any time. Select File in the top-left of VEXcode, then select Save to save the project, or Save As to save it with a new name.
Screenshot of the VEXcode IQ (2nd gen) toolbar, with the File menu highlighted. Screenshot of the File menu open, with the Save and Save As options highlighted.
